So,
suppose you had dual cases setup both with 2.28 gears, and a twin stick rear case. obvisouly, you would have Hi-Hi, Hi-Lo, Lo-Hi, and Lo-Lo capabilities...
BUT!.... Hi-Lo and Lo-Hi (2 or 4wd) would give you the same final drive ratio.
(assuming you didnt change ring and pinion ratios between testing
my question is, which setup would be harder on the truck in terms of stress? putting the front case in low and the rear in hi, or the rear case in low and the front case in high?
seems like since the rear case is obviously further from the source of torque (engine) that it would see more stress being in low rather than having the front case in low and the rear case passing through 1:1.
sound right? or is my brain convincing itself of something thats not there
