- Location
- United States
Essentially new HyperSpark distributor, albeit lightly modified to fit the 2F - unit is a modified Jeep 258 version (565-307).
Story:
I was working on assembling my frame-off '76 in 2020 when an alternator/regulator issue and voltage spike killed the hall effect sensor on this unit. Due to "other events" at the time in late 2020, repair times from Holley were on the order of months, so I just ordered another one to keep my project going. I later sent this unit in for service/warranty in Sep' 2021 - unit has under 30 minutes of runtime on it.
I've been running this same setup on my 2F with the Sniper and the Holley CDI and coil for about 2000 miles, and it's a nice setup. Works well with the Sniper, and the ability to control timing and not just rely on the IAC does help down low.
Essentially plug and play with Sniper wiring when used with the HyperSpark CDI box and coil - NOT INCLUDED:
www.holley.com
www.holley.com
Will need a hold-down clamp along these lines, but cheap to procure:
Amazon product ASIN B00MI5RJTA
Included:
Some details on the mods here - no secrets, fairly minor:
Holley Sniper (and Hyperspark!) Install, First Start : (FJ40 Week 41) - https://www.youtube.com/watch?v=3RJfL5R-7Rw
Story:
Holley Sniper EFI 556-151 Sniper EFI HyperSpark CD Ignition Box
Do you need to upgrade your ignition system due to a recent Sniper EFI installation, but have no idea which option is best? Introducing HyperSpark Ignition, from Sniper EFI. The complete system consists of a CD Ignition Box, Billet distributor with Hall effect crank signal sensor, an ignition...
Holley Sniper EFI 556-152 Sniper EFI HyperSpark Ignition Coil
Do you need to upgrade your ignition system due to a recent Sniper EFI installation, but have no idea which option is best? Introducing HyperSpark Ignition, from Sniper EFI. The complete system consists of an ignition coil, CD ignition box, billet distributor with hall effect crank signal...
Included:
- Modified Distributor, essentially new in box
- An email copy of my current tuning map (fuel + timing) for use as a base
- not a dyno tune, but from miles of road tuning; representative of a mostly factory timing curve
- Additional tuning does require using the Holley software on a laptop (not the dash screen), but fairly straightforward
- ** Up to purchaser to verify final tune and fitment **
