humming sound when warm
One of Four Presidential Flying Saucers
This has just started recently, but when the engine is warmed up, and at idle after I run the engine above 1200RPM or so, I get this humming - almost sounds like a faint trumpet - coming from the carb area. I've unhooked all of the vac lines running to the carb and in the area of the manifold (one at a time) and the only thing that seems to stop the sound is if I pull a big air sucking vac line (while it's going - it happens almost randomly. I can rev the engine once and it won't do it, rev it a few times and the sound will start up. Also, if I let it idle for a while, it will randomly start and stop.)
I'm leaning toward it being the EGR (though I pulled the vac lines from it and it really didn't make a dif - pulling the main line did make it stop humming, but it was about to stall the engine at the same time). Anyone else have this weird sound and know what the cause is?
Hmmm ...
Fan clutch ??? Try ruling this option out.
HTH,
Cahil
It's not anything mechanical, and the sound isn't anywhere near the front of the motor. It's isolated to the side of the engine, near the carb. My symptom searching comes from sticking my head under the hood, not trying to guess what's making the sound from the driver's seat.
The sound is definitely one of air/vac passing over or through something and it's vibrating - just like a trumpet. Just can't track down what it is. I even tried using a rubber hose stuck in my ear and going from one object to another, but the engine noise clouds it over.
Then try a good mechanic's stethescope ... and you should have no problem isolating it.
HTH,
Cahil
PCV valve.
Spray some water around and see if you can change the frequency of the noise.
Pinprick hole in a vac hose,leaky carb base?
