Hub lock nut socket 54mm and 50mm
kiwidog
Kiwidog
Red Deer Alberta
Here's my Christmas break project.
Hub nut socket with 54 mm later and 50 mm early in one tool.
Started with 2 1/4 od exhaust tube.
The 50mm nut is OK for the inside diameter of the tube so I just heated and forged till it fit.
The 54mm end with made out of 3/4 x 1/8 flat and cut and welded to form the hex. I used piece of plywood cut to a 54mm hex to hold the pieces while I tacked them together, use gas torch to weld the six seams and filed them to fit.
Them gas welded it to the other end of the tube.
Drilled a couple of holes to use a bar for leverage and then it was done.
Another SST for the box
Thanks jbhttp://images.ih8mud.com/images/smilies/beer.gif
Nice project. Good work.
Well done.
Just make sure you never tally up the labour cost:D
:cheers:
I hate seeing chisel/screwdriver marks on hub nuts too!
