I have a dual battery setup done by Iron Pig Offroad in Fredericksburg, VA (who do *awesome* work, btw). I typically leave my cars on a trickle charger, because I don't drive them very often. But I noticed something ever since I had the dual setup done; trickle charging with the dual battery doesn't "work" as it typically should.
- If I place the charger on the primary (starting) battery, it takes FOREVER to reach full - and I mean like 3 days. Even a completely dead battery typically fully charges in 24 hrs.
- If I place the charger on the secondary (accessories, winch, etc) battery, it'll charge, but when it's done, the charger will give an error code.
Both batteries are NEW. Basically I think having both batteries on a single circuit prevents the trickle charger from working as it normally would.
I know the simple answer is just to remove the positive terminal from the battery I wanna trickle charge and then place the charger on it, but:
A) That's a PITA to do every time, vs. simply removing the charger and you're ready to drive.
B) Removing the positive terminal from the primary battery means I gotta reset all my presets (radio, clock, etc) all over again, each time.
Wondering if anyone else has any ideas/insight on another simple way to make this work.
TIA!
TIA!
