Many thanks to this forum (Hoser,Hkeller,Lexusben Texasoiland Uhu in particular), I was able
after grinding a 36 mm spanner down to 8-9mm thickness to change both the rear flat
accumulators of our 2000 LC100 (not too difficult;just one sphere was a bear to get loose!).
Now I am facing a blinking OFF Heigth Control sign on the dashboard when starting the engine
with the HP hydraulic pump refusing to start.
As Texasoil says : What gets most 'techs' is lack of understanding!
we bought this LC100 when transferred to France, mainly to be able to trail a boat south to
the mediterranean . We noticed that when the load was not properly balanced on the two axle
trailer, the AHC was set to LOw ( I think with OFF sign blinking as well on dashboard).
A few visits to the Local dealers made us realised these people did not have a clue and
could be quite expensive ( talking about changing the whole system!!!).Anyway, the AHC was
resetting itself after a while.
I tried to understand how it works, with the help of my EPC disks ( remains of our HDJ80)
and a visit underneath the car and within the engine area. Hydraulics can be easily
understood, but the electronics or computer logics without a manual is just impossible.
So I bougth a FSM ( 4.2TD engine) on ebay: bad luck, it is for a UZJ!! ( without AHC).
Then I started to have this bumpy ride on the rear that can be.. a bad sign for your
finances.
I discovered HiMud forum, understood why we could have the AHC on Low when trailing; did the
test of the 7-8 marks and found a difference of 12 graduations on the reservoir !!!!,
deducted this could be due to nitrogen from the accumulators increasing in volume due to
lower pressure after channeling out of the membrane, and decided to change the accumulators.
Well,I had the local dealer to double check if the price of brand new accus was for real,and
decided to go for second hands( not easy and quite long to ship from B and B ; and ...no
local dealeryet).
By the time we found a salvaged 2005 LC ( same P/N for the accus), I had to keep using our
LC from time to time. Then this OFF sign started blinking on the dashboard with AHC set on
Low. It remained for one week, then disappeared, with pump working again . I did avoid to
use the car until we received the accus.
The day I changed them, the OFF sign was there again ( blinking one time per second
approximatively).
After changing ( the old accus membranes were indeed flat out), pump still did not work; I
tried to bleed off the pump by releasing the HP outlet ( same piping for discharge and
return); liquid go thru , but pump do not start.
Now, this is all I can do without understanding which safety sensor or which logic need to
be reset .
I did read the thread about resetting the DTC ( diagnostic trouble code) , or starting the
pump manually ; and as a first contribution , I join here a schematic of its PINs. But I am
not sure which is the proprer procedure to reset/bleed the system to have the pump
to run again ( of course I am taking the assumption our pump is still OK).
Anybody had this experience?
finances.
local dealeryet).
approximatively).
be reset .
