How to remove panel for antenna
TX
Ok I've had about enough trying to figure this out on my own. how on earth are you supposed to remove the panel to access the power antenna motor?? I see that one bolt that holds down the end furthest from the seat, but that's all i got.
You get to the motor vis the right side fender liner. Don't have top take it out totally, just remove enough of the plastic clips and a couple/three torx screws (on the LX anyway). Then pull the plastic away enough to get in there with a 10mm wrench on the mounting bracket. To totally remove you will also have to unplug the wiring connector that's on the mounting bracket as well as removing the nut at the top of the fender.
