How to properly adjust vacuum advance on distributor (1 Viewer)
Arlington, TX
What is the proper process to adjust the vacuum advance on the distributor.
The screw on the side of the vacuum advance fell out and I don't know what correct process is to set it.
I see that you can compress/squeeze the vacuum advance up to the 2 set nuts and then tighten the set screw. I don't know if that is all that is needed.
