I've got a 2005 sequoia with open rear diff. I was originally planning on doing a lunchbox locker in the back and living with the noise/driveability quirks. Now I have a line on a Tundra LSD for cheaper than a powertrax no slip.
Right now me sequoia is stock aside from worn 265/75/16 K02s. My proposed build is very simplistic and budget minded. 2" lift, skinny 33's, winch.
I'm not really finding myself with one wheel totally off the ground, just in loose terrain where power ends up at one rear wheel. Traction control is a little too intrusive to actually help me out. The install seems similar of each. Both require removing the 3rd member and ring gear. I'd just swap my 4.10 ring onto the tundra diff. Then make sure preload and backlash are within spec. Would the factory LSD from a tundra be a worthwhile upgrade?
