Holley 2 barrel carb, with all the stuff: Don't know what model this is, but marked at top of intake "LIST-7448 0798". Came off my 71 FJ, and worked fine (replaced with Weber 38 on my rebuilt motor).
Comes with "DOWNEY TOYOTA" aluminum adapter/riser (1"), with allen bolts (4), and a composite (plastic/bakelite?)riser (5/8") with vacumn intake tube.
L-Bracket for attaching throttle cable, and well-made extension bracket (attaches to oil filter bracket) to attach throttle return spring. Carb is set up for manual choke.
Unknown brand chrome air filter housing: 9" dia. Takes a NAPA 22906 filter. (you can have the serviceable filter,too). Minor rust flecks on this cheapie filter housing: they might polish out.
Couple of new flange/riser gaskets. NAPA 60716 and 60094. Still in plastic.
If you're interested, I'll go ahead and pull my old throttle cable out of my rig and finally install the new slightly longer one that came with the Weber. You can have the one that worked well with this carb. Minor "clamping" smash on the end where it attaches to the trunion. Very serviceable. (I've been using it.)
Basically the whole enchilada to put a 2-barrel on your F-motor. Whole rig cleaned (but not detailed) with carb cleaner. Ready to go.
Asking $150 plus shipping. I'm in Forest Grove, OR. (97116).
