Hj75 cruiser starting problem
Hi I've got a hj 75 cruiser when I try to start it all the lights just flash on and off and I just keep getting a loud click any help will be muchly apppreciated
A little more detail? The loud click could be the starter trying to turn and the lights are going out because all the electrickery is trying to turn your starter.
Sent from my iPhone using IH8MUD
First off!
Make sure your battery is good, check connections, if in doubt put the positve lead to the starter itself.
From there fuses.
Next a good whack on the starter can temporarily fix a problem, use an axe handle, bat or other suitable decice.
Again make sure you have power in the battery first, boost! then do the rest.
