HJ61 VX stereo install (4 Viewers)
Hello there are other threads on this but most are very old and some are making my head spin or seem to involve people trying to do complex setups. Though if I'm missing one I'm happy to be redirected.
I bought a new alpine double din touchscreen head unit to put in my HJ61. Yes it is a 24V truck, but the head unit says 12V so I am assuming I have the in-dash converter.
I am trying to see if anyone is aware of what adapter I could buy to allow me to simply plug my stock wiring harness into the modern head unit.
Alternatively if no such adapter exists, if anyone has a wiring diagram so I can hardwire the stock harness wires to the harness that comes with the new head unit that would also help as I can't seem to find a clear answer on this.
I will include pics of my stock radio and harness so it is clear which audio setup the truck has from factory.
Years ago I wired a single din head unit into a corolla and that's the extent of my wiring and audio experience so I'm noob level. Also i am selling this original HJ61 radio if anyone is interested in buying it. But it was not fully functional when I pulled it out.
I'm interested whenever you are ready... Not in any hurry, but trying to put mine back to stock
It will be yours once I get this situation sorted. Please note - as I mentioned above - it was not functioning while in the Truck. This could be because of an issue with the radio or with some issue with the truck wiring but I wont know until I see if the new unit functions when installed. If so then you will know the radio itself will need messed with to work before you install.
what did that connector in your fingers plug into ?
Factory head unit. But the "premium audio" one not the standard 60 series style.
can you show pics of what that single plug plugged into ?
i am very familiar with this topic , at least the TOYOTA sides of things ....
i am NOT interested in buying your old radio ...fyi
but i do have all the audio plugs toyota ever made to circa era 1997 ish
Sure here is the old radio front and back. As far as I am aware, this was also in some 70 series prados.
you need to post photos so to better help me help you ?
as i understand it we are dealing with 3 radios in all ?
it looks like that single plug in your had goes to 2 smaller plugs down the line ?
there are countless audio plugs in the timer period , simply having or saying you have PREMIUM audio does not really tell me much except you may have a SUB-AMP involved after the radio to your speakers .maybe ?
ok ,
so you need a MALE plug , to connect to that Female plug in your fingers above / a Pigtail Adapter ?
it will simply have Leeds on it 6-8 inches , it will be up to you to connect to any aftermarket radio ,
the new non-Toyota radio will have printed instructions to do this
Yes i appreciate you trying to help. Your a god send on here btw.
The single plug in my hands in the original pic for this goes directly into the slot you see on the back of the radio. That's the only radio. Just one plug that plugs in. Those other two you see further down the line still connected may or may not be the normal 60 series dual plugs, but I'm not sure if they are and not sure it would matter.
since this is a 24v truck there is a factory converter further in the dash that all these wires run to. That drops it to 12v so the radio can run. But a multimeter showed that the two dual plugs produce 24v. So even if they are the normal style plugs they are prior to the converter and therefore won't work for anything 12V. So that 12V 14 pin plug you see me holding is the only plug/harness i have to draw from. And as stated, the only plug on the radio other than the antenna wire.
I am trying to replace this setup with an Alpine new touchscreen unit. I have searched for an adapter for this plug or wiring diagram for this setup but they don't seem to exist so I have no idea what wires are what.
ok ,
Yes I am familiar with how the aftermarket radio end will work but the issue is finding out what the setup on that plug is. The 14pin connector from the truck seems like a rare item.
it is
ill dig into this plug connector you need and let you know what i come up with
It has 14 pins which.....seems to be correct. I'm not aware of any other time toyota used this 14pin connector in this era except for this radio. Does it exist in the wiring diagrams?
I’m in the same boat with my HJ61. Is there any update to this? I would prefer to leave the harness intact and not cut the factory plug off.
Never found any adapter that was definitively going to work. There is one sold in the UK i think that LOOKS like it MIGHT work but it was like 50 bucks so i didnt want to risk it only for it to not work.
I ended up just having to cut the whole thing out and hardwire everything. Tested the various wires with a continuity on a multimeter to figure out what went to what, etc. Just got rid of the entire built in amp/converter under the dash because dealing with it was insane.
What setup did you go with? I am looking at a couple different options, but an aftermarket 12V regulator seems to be the best. I'm just concerned about parasitic drain on the batteries.
I used two diodes to fix the parasitic draw issue and install a normal modern alpine touch screen unit. It also retains memory.
There is another thread on here about how to do it, complete with a wiring diagram. I think in that mudders case it was a 70 series but same exact situation. If you cant find it yourself i may be able to when i am home later as i am out on my phone right now doing stuff.
Search "24V radio memory" or something because it was a guy with a 24v 70 series who wanted to prevent drain from memory draw if i remember correctly. Could be wrong about that. If you have a 24v cruiser like me youll also need a converter.
  • Back
