For Sale HJ60 parts, 2H parts, some 3B, some 60 series
UPDATED! Please see what's still there.
I am selling my spares-please see the lost below.
Here's how it will work:
I take paypal or you can send me a check.
I will try to ship everything that sold this weekend, otherwise the weekend after.
Shipping is NOT included in the prices and on your dime.
Local pickup works in San Diego.
You can communicate with me by PM or email (karlseder@salk.edu)
I will upload pictures here, but if you want specific ones, let me know. I'll try to take them asap then.
Here is the list (sold parts will be indicated as such):
Starter repair kit 2H starter (contacts and plunger) $40 SOLD
clutch master used (boosted clutch, same as 3B) $10
clutch slave 2H new $30 SOLD
valve cover seal 2h new $25 SOLD
radiator cap 2H aftermarket $5 SOLD
front brake lines hard line connectors to the calipers OEM new $30 for both
rear main 2h (2, one older style, one newer) $10 for both SOLD
Aisin hub, dirty but works perfectly $50
2x FJ80 tie rod ends $40 for both
2H preheating timer 2h 3B 12V (28521-68030) $50 SOLD
Fuel control relay/EDIC relay 2h 3B 12V (28590-56090) $100 SOLD
Voltage controller 2h aftermarket 12V $30 SOLD
Throttle cable OEM FJ62 (78410-90A10) $30 SOLD
Front end kit SOR 080590-B $20 SOLD
Window regulators 60 series $50 for both
bellhousing 2H $40 SOLD
Tranny mount H55F used $30
4WD sensor with one broken wire $5 SOLD
2H alternator 12V rebuilt with vacuum pump $300 SOLD
Clutch booster 2H 3B rebuilt fully working plus spare parts $150
oil pressure sensor 2H 3B 12V OEM new (83620-60010) $50 SOLD
vacuum pump brand new $150
2H water pump used, working $20
Brake booster HJ/FJ60 $50
rear lens FJ/HJ60 $5
wheel spacers 60 series 1/4 inch $20
oil catch can (POS) $5
rear wiper motor 60 series $20
side vent 60 series (one only) $5
brake master cap with wires $5
2H exhaust manifold one piece plus heat shields $50
bell cranks (not frozen) 60 series $20
steering arms 60 series $10
door handle 60 series (don't know driver or pass) $10
engine mount bracket passenger HJ60 new style (has the power steering pump mount on it) $20 SOLD
speedo cable used $5
Land Cruiser emblem, has studs, gasket broken in half $5
seat belts rear lap 60 series brown $20
passenger mirror 60 series after market $20
Engine rubber mounts 2H, old style, 1 used $10
Engine rubber mounts 2H, new style (after 9/84), 2 new $40 SOLD
FJ62 rear wiring harness in great shape, from fuse box back $50
power steering pump 2H old style (prior to 9/84) used, leaks, comes with new gaskets $20 SOLD
3.70 gears 60 series, used in good shape $100
2h rebuild parts, all OEM new $700 for all, or make offer for individual sets ALL SOLD
Valve springs intake and exhaust full set (90501-42006 and 90501-26017)
rockers 12 (13811-68011)
push rods full set (13781-68010)
pre cups 6 (11106-68011)
valve seals full set (90913-02050)
2H engine, needs rebuild $500 SOLD
This engine only has 183k km on it, but has a slight knock, so it needs a rebuild. I have not verified this information, as I bought it out of the truck.
The head is almost certainly good and it has the injector pump on it (from a manual truck). No picture at this time.
24V wiring harness HJ60. Has many relays on it. No picture at this time $200
That's it for now,
Thanks for looking,
jan
pics
pictures
Normandy Park Wa. ........now in San Diego Ca.
I see your back in town...
Jan Ill take this
Might even take the 2H......I ll give ya a call
Chris
Jan Ill take this
Chris
Sounds good.
I'd love to not have to ship the 2H!
cheers,
jan
Modesto, CA
Jan
Second in Line for the 2H
Also interested in the rebuild kit (parts) for the 2H and other stuff for the swap
Will give you a call.
Keif
Some of the stuff I'm interested in as well...
bellhousing 2H $40
Two Buck
Nowhere, NM
I'll take the seatbelts. Do you know if they feed and retract without hanging up?
Sending PM...
S. Lake Tahoe, CA
I'll take the aisin hub. Do you have the pitman arm off the 60?
