For Sale HJ60 package (3 trucks) for sale
I have a sweet package for sale:
1x 1987 HJ60. Silver body, grey interior. 280000kms, 2H engine, H55F, OME medium suspension (including shock absorbers, shackles and bushings). Transmission and transfer case bearings and seals replaced. Rear axle serviced with new pinion&ring gear, diff AND axle bearings. Installed a Auburn LSD. Front knuckle serviced (new everything). H-duty front bumper.
Misc: Factory AC (still working), Hella headlights conversion with replaceable bulbs, VW Passat heated seats with controls, VW monsoon radio with Phatbox, 8 Clarion speakers. 24Volts system still there and not modified. 12V system installed (2nd alternator with independant electrical circuit, 120A alt. capacity).
The bad: Yes it is rusted, but still good enough to be restored without spending a lifetime welding sheet metal. Some rust spots on doors and fenders, rear wheel arches are the worst. Some work on the floor has to be done around rear wheel wells and driver side close to the door sill. Rear tailgate not bad, rear hatch to be replaced or repaired. This truck was sprayed with the greasy gooey stuff inside all doors, panels and prone to rust spots. The rust you see from the outside is all you'll get, since all inner surfaces are still greasy with no corrosion. This truck works great (my daily driver). Frame is not rotted.
1x 1987 HJ60. Green body (was repainted), brown interior. 350000kms. 2H engine, H55F transmission. Transfer case was sold. This is a parts truck. Would do a great mud buggy or offroad fun vehicle. Body rusty, but I've seen lots that were far more rusted than this one. Frame is rusted and perforated near rear axle. SOA, but was done by poor mechanics, so not very well done. Sagging leaf springs.
Good axles, diffs and housings, good interior (missing passenger seat), Windshield and windows good. fuel tank with NO rust. Engine had an exhaust leak in coolant, but was immediately stopped once it gave signs of higer coolant pressure, so not much damage to be expected. I don't have any paper of this truck.
1x 1986 HJ60. Silver body, grey interior. 350000kms 2H engine, H55F transmission with matching transfer case. This is another parts truck, but this one is very interesting.
The tub was chopped in parts and sent to the junkyard because of rust. Same thing with all 4 doors. This truck was on a frame-off restoration process when I got it. Everything is in boxes and was carefully dissassembled. All bolts, brackets, springs, basically all the little steel pieces were sandblasted and anodized to aircraft specs (the previous owner was a retired guy from a large aircraft manufacture). Frame was sandblasted, repaired and then POR-15. Axle housings were also blasted and POR'ed. Fuel tank was recoated. I have the complete interior in very, very good condition. Front fenders, front wheel wells, hood were repainted, but it's not the original toyota silver (its a dodge viper silver color), so they will have to be repainted to match the exact color. Rear hatch and tailgate need little prep (surface rust) and paint to be perfect, but very good material to start with.
2H engine was completely dissassembled, block was sent to expert engine shop for oversize boring and all checks (dimentional, cracks, etc). Crankshaft and camshaft were also checked and carefully polished at the same shop. Cylinder head checked and serviced. 6 injectors rebuilt and pop tested. Injection pump bench tested and was found within specs. 6 oversize pistons matching this block. All new parts to reassemble (bearings, piston rings, gaskets, seals). New rocker arms, rocker shaft. Also a brand new turbo with all flanges and fittings to do the mod. Only the exhaust manifold to build.
Many, many other parts not mentioned here that will be included int the sale.
The trucks are 150kms north of Montreal, Quebec, Canada
You can send me an email at: dgilzboat@hotmail.com
Price for the three trucks (WILL NOT SEPARATE) is 6,000 CAD$. This is planets away from what I've paid for these trucks, but I have to clear the floor and have not enough time to finish the project
They are listed on kijiji.ca if you want to look at pictures:
http://quebec.kijiji.ca/c-autos-et-...yota-Land-Cruiser-HJ60-SUV-W0QQAdIdZ491327482
Nota: You can notice the nice silver body panels on the wall of the barn when looking at the rear of the green truck.
Thank you for your interest and please do not ask me to sell parts or separate the three trucks.
Gilles
HJ60 Package
Here are some pictures...
