Hi/N/Lo dash light
California
I had my suspension lift installed with AHC delete to rear airbag to coil conversion and noticed that the Hi/N/Lo dash light indicator is no longer showing. Is this normal? Thanks!
Yes.
You remove the air suspension. If the fuse left in place it would flash indicating fault all the time.
Hmm...my dash light is still on, in the ”N” position where the airbags had been when I pulled them.
No fuse pulled, yet no blinking light either.
Which fuse is it to defeat the dash light entirely?
theres a relay you pull from the little box attached to the fuse box under the hood. Also, a fuse in the fuse box thats needs pulled aswell. I wish i could recall EXACTLY which ones, but im at work at the moment and dont have access to under the hood to look for ya..
Quick search on this forum and you should be able to find a few photos pointing you in the right direction.
Thank you for that.
Easiest “mod” I’ve done on the truck, and it worked perfectly.
Now, all signs of my deleted ride-height System (AHC) are gone.
Happy to get the clutter off my instrument panel.
