Help with tubing and bending service in ABQ
7600ft Tijeras, NM
Putting in the full profile metal tech cage kit in my BJ 44 and need two additional pieces because of the length discrepancy from the 40. Can anyone recommend a source for the tube and the bend? 2" DOM 0.120" wall. I found the two 54" long pieces at NM metals for $110 without the 15* bend I need in it. The two bends can be done at Anglim's for $95 "minimum" for one per/hour charge, ouch.
Anglim’s will get it done, and done to spec.
You could try Saltey Dogg Metal Fab.
You could also try some of the racecar builder/shops in town for a lead on a place that does roll cages “oftener”.
Have Metal Tech do the bends. They have the design, tubing, and bender. Helping out a customer?
I've tried. Metal Tech will only sell components the full profile cage for the 40, even with the 43 parts still advertised on the site:frown:. They don't do the work on the parts apparently. So local sources it is.
Will do mañana.
Ended up getting the pieces in stock at NM metal. Anglims was the only place I could find that had a 2” die, didn’t try affirmative…
