Help with brake line removal
I'm in the middle of my first birfield rebuild. All was going smoothly until I tried to remove the rubber brake line from the brake shield plate. The nut was easy to get turning but there is no swivel so as I loosen the nut the hose just keeps winding up so I cant loosen the nut anymore. Is there a secret to getting this line disconnected? I figured i would replace the lines with stainless before this is all over anyway, so should i just cut the line or what?
Thanks
What Jwest said, disconnect the other side
Toad
Nope, It'll spin right off
Toad
I had the same problem as you.... I ended up cutting the line since they were already cracking, but if you look at where the soft line connects to the hard line on the axle, you can unscrew the hard line. After there is a retaining clip that holds the soft line that you gotta push out with a flat head screw driver. Then the soft line will pull thru the bracket.
So don't unscrew from the bracket on the caliper, unscrew the line first from where the softy and the hard line meet on the axle.
-Kevin
Here's removing sequence.
1. Disconnect steel tube from back.
2. remove e clip
3. remove square c clip
4. then you can remove rubber hose.
Oh, Min Seok
I am trying to remove my lines for the extgended ones (frame to axle) and running into the same thing. I am having a tough time getting the hard line to come loose. And there certainly isnt alot of space and having to use 2 hands i to hold the soft and one to turn the hard. Any trick for thast one?
