help with 2003 tacoma
gloucester MA
lost all turn signals I checked the fuses but nothing was blown
if I turn on the switch not evan a light comes on.
could it be a bad relay ?:confused:
Do your Emergency flashers work? If not, and you checked the fuses both inside the cab and under the hood, your flasher unit might be bad. If they do work, then you could have a bad turn signal switch.
I would also verify that all the bulbs are good because I am not sure how the new trucks act when they blow a bulb.....
nothing works hazard or turn signals and all the bulbs are good.
thanks for help it was a bad flasher relay
