Hi, I’m new here and new to working on cars beyond basic servicing. I bought this land cruiser Ute hoping to learn but I might have bitten off more than I can chew.
I bought it a couple of weeks ago and noticed it was blowing a lot of smoke.. after investigating I found a oil leak behind the turbo and am guessing the oil is burning in the exhaust causing the smoke.
I did some reading on the matter which lead me to check the oil return line which appeared okay (not clogged or anything)
I removed the air box and there was oil and there was oil residue in the air intake pipe close to the turbo (not sure if this is normal)
I then turned my attention to the wastegate noticed the previous owner had zip tied a link in the tube leading to the wastegate which I removed (not sure if this will help)
My question is what else can I check/try to address the issue. Any help appreciated!
