Hi everyone,
I'm getting ready to install my (generic) snorkel to my 2000 Hilux Surf (1kz-te diesel engine). My airbox is on the opposite side to you gas engine guys, but the principle is the same.
I've done a lot of research into products which can be used to seal the various snorkel/airbox joints, especially in the fender, but i'm wondering what you guys use to seal the actual connection between the intake and the airbox.
These toyota airboxes have a bit of an opening where the intake pipe is larger than the receiving airbox pipe, with just a small foam o ring between the two (mine disintegrated ages ago).
I don't want to use any sort of seal that I won't be able to remove if I ever need to pull off the airbox to do work on the engine or to access anything, so I'm trying to think of ways to seal off this joint but without anything that would permanently bond the two pieces together.
I've thought about finding an appropriately sized o-ring (measuring the intake pipe with a caliper?) but being here in Jamaica the choices will be slim to find the right size.
Thanks!
Thanks!
