so i just got done replacing the clutch in my little brothers cruiser. when i took off the slave i took the adjustment bolt all the way out and the plunger and fluid came out. when i put it in again i bled it, but i think there is still air in the line somewhere because it won't push the clutch fork unless i pump it a few times. i did a search and it said to gravity bleed it and then pump the clutch a few times and while the clutch is pressed to the floor to reinstall the bleeder valve. i did all that, but i still have to pump it to get it to work. what do i need to do.
oh yeah-when i bled it i took the whole bleeder valve out, would that have something to do with it? is the plunger possibly in backward? i don't know.
