Can anyone help with this? Went on a trip last week, when I reached about 5500' above sea level the 2f turned into a dog wouldn't rev much past 2k rpm.
Only on 1978 2F.Check your vacuum hosing and disconnect and plug the retard hose. (The one that goes to the diaphragm closer to the distributor housing.)
But caution this will cause engine knock at low altitudes and you will have to use premium if you not set the timing back.
I live at 4K feet here in Oregon now and get around pretty good but with 33" tires I stay in 3rd a lot.
the vacuum hoses on the carb, on the air rail side often get cooked. My rig was running crappy until I put all new vacuum hoses on. the ones on that (passenger/starboard) side of the carb were cracked and broken. Replaced them.... Idle problems solved. and it ran way better (still no v8).. might help you to check.
