Help needed....someone with a PZJ and A/C arround?
Darmstadt, Germany
I have installed a A/C in my PZJ 75 which was took from some short version of a J7 typ with a HZ1 engine. everything fits fine so far, just the electrics behind the glove box does not match as expected. I got an extra cable delivered which connects to the main cable tree which itsself connects to the A/C amplifiyer, the pressure switch and the temperature sensor , but that does not fit my main cable tree. Instead my cable tree holds its own free plug for the A/C amplifyer and has two further connctions which would by cable number perfectly match the one for pressure switch and temp sensor, but the plugs are total different. So what I need: How the the cabling done of the original PZJ with A/C, especially the pressure switch and the temp sensor.
maybe some pics help.
ok, thanks. now it is clear. the extra cable which I have does not match. I will try to figure out the right cable today...
is there a particular part number on that cable?
what would really would be helpful: how is this extra cable connected to the mail cable. maybe I can sort this out by cable colors.
No part number attached but when I look it up on the diagram, it shows to be 88605-60650 for my particular model.
I can’t imagine this small harness being too difficult to duplicate if you can get the connectors at least.
so the plan will be to use the existing cable and make it fit. The number of cables is on both side 7 and the colors also seem to match. What made me go the detour was, that the origigal cable exactly could fir the a/c amplifyer and there where 2 x2 cables left which fited perfectly by numbers. but now I know this is not the way to got. Thanks to you and the wireing picture.... so basically now i will find a solution
