Well it snowed two feet last night here in Wyoming, and I moved my 05 LX 470 across the street into a parking lot so I could shovel. When I got back in the car, I couldn't turn the key in the ignition. It's stuck in the "lock" position.
The steering wheel is loose, and I've turned it back and forth so I don't think that's the issue. I sprayed houdini into the lock cylinder to perhaps loosen up the tumblers - no luck. I tried tapping on the cylinder with a screw driver, tapping the key, and several other tricks to no avail. Also I tried my spare key which performed the same.
I read several threads using the search function and there was a great write up on how to fix a lock cylinder that turns but doesn't start. However I couldn't find anything for my situation - the key won't turn at all.
I called the dealer which is 300 miles away in SLC, they said I would have to have it towed and offered no advice. I can't imagine what the towing bill would be for that distance so I'm praying and rubbing my lucky rabbits feet in hopes that someone knows how some way to get this car started! I'm open to anything at this point, I'll tear the dash apart and try anything!
Thank you cruiser masters!
