Help identifying Driver’s side window trim on a 1999 LC
Castro Valley, CA
Looking for the part # for the plastic Aero Trim tab on the driver’s side window of a 1999 Land Cruiser. Not even sure what it called or if it available or part of the window trim. It’s not a big deal just a sharp edge and was wondering if anyone has a part # or what these are called :)
Photo 1 is the driver side and that’s just the metal tab the plastic cover slides over
Photo 2 is the passenger side with the tab in place
May be called a window guide or window felt.... I think. Put your vin into Partsouq.com and start searching through the body portion, you will have to find the door schematic and look there.
62367-60030
Awesome, got it ordered up
Any clue on how to remove the clip, or will I be able to just replace the plastic trim piece that’s missing?
Thanks Again :)
The cap is bonded to the clip. You would wreck it getting it off. The portion that goes in the channel needs to be pinched together to pull it out of the channel.
Hi there, sorry to resurrect an old thread like this. I was missing one of these on the passenger side of my 2000 LX470 and ordered a replacement as OP did, but is there a reason why the replacements aren't shiny and smooth like the original one I lost? Is this something I can or even should refinish? Or should I just put a second replacement on the drivers side as well. Just knowing they don't look the same is gonna bother me!
