Hi All,
New on the forum and looking for help with a problem.
Riddle me this, guys and girls —
I’ve got a 2008 4.5L V8, and it’s throwing up some dash lights and error codes.
Code: P0748 – Transmission Fluid Pressure Solenoid
It’s causing 1st gear to be non-existent, and it seems to default into 4th gear as standard. I’ve got an OBD reader, and when I’m on the motorway I can clear the code — if only for a split second — and it’ll shift out of 4th (to what I assume is 6th) The codes come straight back up, but it stays in the higher gear.
If I pull the gear selector over to manually change gears, it defaults back to 4th and won’t let me go any higher manually.
I’ve had it at a couple of garages and even had the solenoid replaced, which we assumed was the issue (see picture). Still no difference. I had a second garage check the auto box, and they confirmed all the solenoids are working fine.
They’ve suggested it could be a wiring issue or potentially an ECU fault.
Has anyone come across this before? It’s a right pain in the arse trying to get it sorted.
Any help or advice would be greatly appreciated!
