<<<You do not want to use the VTV on the vacuum advance hose with the HEI dist or you will have knock problems.
Actually, the VTV will reduce knock problems by slowing down the vac advance.>>>
Hi Jim, didn't know you were on this board.
I may be way off and slap me if I am wrong( I don't have the 87FJ60 or the FSM any more)
BUT
Looking in the Haynes and from what I remember the VTV would let vacuum get to the dist, advance it, and hold it there when there was no longer vacuum from the carb.
The VTV has a dark (side B) and a light (side A) side.
Per the Haynes it says to check the VTV
"Check to see that air flows from B to A but is does not flow from A to B"
THe way the VTV is on the vacuum hose it that side B is towards the dist and side A is towards the carb.
Thus vacuum can advance the dist when you open the throttle. When the throttle is closed there is a delay before you loose vacuum to the dist.
If you had the VTV on the wrong way (I had it hooked up the wrong way for some time and had NO vacuum advanve) you would have no vacuum advance.
Maybe there is more vacuum advance on the HEI dist so having the vacuum advance held for a short time is to much advance, thus causing knock.
When I removed the VTV, I no longer had knock when going driving in the hills.
So If I have this right:
When the throttle is closed, there is no vacuum to the vacuum advance.
WHen the throttle is open, there is vacuum to the vacuum advance.
With the VTV, the vacuum advance is advanced for a short time after there is no longer vacuum.
Let the "slapping" begin
Jim didn't you tell me that the max advance needed to be less when you remove the EGR?
