Headlights: low beam, high beam height differences
Denver, CO
Hi all,
1998 LC...after adjusting both my driver & passenger low beams to the proper height, my passenger high beam is pointing at the ground (driver high beam is at proper height). Anyone else ever have trouble with this? From what I've found, there is only the one adjustment screw for the whole headlight, not independent screws for each of the low & high beams. Can't win..low beam is either in the sky & I can't see or high beam is on the ground & I can't see. Does this require a headlight assembly replacement?
Thanks!
Check your globes are seated correctly in the holders. This may require removing or at least shifting the battery.
Cheers,
Greg
