For Sale HEADING TO THE SCRAPPER SOON! 92' fj80 in kc kansas white with grey interior
KC, KS
Last chance for most parts. I'll plan to be hauling it off in 48 hours or less.
Call / text Dale @ 913-909-1594 for immediate response. Mud works too if you prefer. Thanks
I still have the following parts for sale. If you need others don't be afraid to ask.
3fe Engine parts:
Engine wiring harness
Head
Thermostat housing
Smog equipment
Water pump
Fan clutch
Oil pump and pick up
Fuel injectors
Fuel injector rail
Belt tensioner assemblies
Belt pulleys
Valve cover
Alternator
Starter
Distributor
Intake manifold and sensors
Exhaust manifolds
Air filter (tuna can)
Complete transmission
Transfer case
Drive shafts
Front, and rear axles
E.c.u.
Main cabin wiring harness
Cruise control actuator
Various modules
Corner marker lights front
Door handles interior/exterior
Grey dash pad without cracks
Good grey passenger front seat
Ragged out drivers seat grey
Sunroof Complete assembly
Antenna (mast is broken at base but works)
Turn signal, headlights, wipers switch assembly.
10 oem aluminum 15" wheels (4 without tires)
Glove box (grey)
Ignition tumbler with one key and electronic components
Door locks (two front) and glove box lock matching set includes one key (no hatch lock).
Instrument panel (gauge cluster)
Mirror switch
Dimmer switch
Rear heater switch
THE BODY AND FRAME ARE GONE.
Thanks for reading! Dale
To the top
PS mirror?
Price shipped to 98003.
Thanks,
Hi,
Any chance you have the center diff lock actuator?
Thanks,
Marcelo
Sent from my iPhone using IH8MUD
