- Location
- United States
Worked without leaks when I pulled it out. Swapped it for a delta console. I also have the opposite connections for the a/c lines I can send with it. Helpful if you're trying to put it in another vehicle. Ice trays and tray door are missing.
Here are the lines. One cut had to be made so I could retain a/c. Im including the location of the cut. Cut line is marked in red. It will get you up in the engine bay and close to existing lines. A custom a/c installer should be able to weld it in to your existing system.
Looking up along the firewall, cut is marked.
