HD Soft Shackle Recovery Points for 60/80/100
Content may include affiliate links. Please see terms for details.
Kantucke
No I have not but similar styles made from 3/8" have a 15,000 kg rating, mine being 1/2" should have higher yet similar numbers. The next run I may do a simulation on.
Some factors such as Hardware and pull angle, and pull type would be interesting to see numbers on.
You simulate at the angle that would yield failure at the lowest loading (intuition or trial and error), then set your minimum safety factor for your listed WLL from this number. That angle will probably be perpendicular to the plane of the eyelet. Are these made from A36 steel plate? Don't forget a HCF simulation also, for those who like to get stuck often. It may cover you if you do this and have a 3rd party load test your findings. Clearly stamp the WLL and breaking strength on them. It would be good to know what an average peak force is for a recovery using a strap or cable (not a yankum style rope). Could use a load cell and test if you had one big enough. As for the bolts you cant control what people use but you could specify a minimum size and grade. For simulation just affix one side of the mounting holes, could use the edge. Or could affix the surface of the plate that would touch frame and assume no separation between the frame and your component. Cool machining and Nice part!
CPACruiser
Supporting Vendor
PA
Yes, these are fiber or co2 cut and milled from a36 HRPO steel, I may mess around with T1 on a future run.
bonestock
Transportation Specialist
Lookout Mountain, GA
Do your points work with an ARB bumper on an 80?
CPACruiser
Supporting Vendor
PA
Once I get 5 preorders I'll throw these in the schedule.
Happy new year mudders!🤟🏼
bonestock
Funds sent.
bonestock
Bump! Let’s get these things ordered! Need a set pronto!
CPACruiser
Supporting Vendor
PA
Had some people message me before the holidays regarding recovery points, they are currently in production and have 4 sets available.
Feel free to message. Have a great weekend.
Tucson
Still have a pair in black PC?
CPACruiser
Supporting Vendor
PA
Currently I don't have any in stock, I can put a feeler out though and if anyone else is in the market I'll whip some up.
Preorders can be placed by sending me a message. If at least 3 sets are preordered I'll get them in the schedule.
CPACruiser
Supporting Vendor
PA
Hey guys I have one set on preorder, would be nice to do a run of at least 3 sets if anyone else was interested PM me asap. Thanks in advance 🤙🏻
