Because I had this 2nd gear popping out sometimes I removed today the top cover of my H55F here in Guatemala.
I made a few pictures of the gears... please let me know what you think!
The gearbox has probably around 200'000km. Working hard since about 60'000km with 3.8tons.
The smallest front gear has some chipping. Otherwise the other top gears loook like new.
No idea on the synchros...
The big fork has on the side that it pushes a worn area. Not sure if that's normal?
The front hub (near the chipped gear) has some groove on the flat surface I can feel (you see it on the picture), but the small fork looks good in my opinion?
Fork width is on both sides the same for both forks. Big fork has very little play on shaft.
The reverse gear has some ugly groove, not sure why? Although, I don't use reverse often...
Please let me know what you think about the trans...
I increased today the spring pressure of the fork/shaft ball/spring setup with a little washer. I hope that helps on the 2nd gear popping out when no power is on the trans... I could push the forks out pretty easy with my fingers out of gear before I increaed the pressure... not sure if Toyota made the hole too deep or the spring is weak...
thanks
thanks
