I posted this on 4wdAction, and I've just joined up here, looking to find a solution, and looking forward to being part of the community!
So I finally got around to putting a gearbox back into my ute.
It is a H55 from another vehicle, which I have determined to be from pre '85. (Whereas my ute was '89).
The bell housing bolted up perfectly to the engine (2H) and is all in place, however when trying to mount the gearbox to the car, the rear crossmember does not fit.
I also swapped the gearbox mounts from the original gearbox to the one I put in, however it seems to be to the left of the mounting holes by about a 1/2". Is it possible that there's any amount of swivel or twist in the gearbox/engine assembly or should I expect all of this to bolt up straight...?
The other thought I had was, is it possible I have to track down the crossmember from a HJ60 or something?
Bit confused and frustrated as it's currently sitting on a jack with the front end hanging off the back of the engine...
