I need some help fighting the leaning of the GX470.
'08 GX470 with KDSS
OEM air shocks, 0 lift [have to have it, since I tow]
BILSTEIN B6 4600
~=1.5" lean to the left [i.e. passenger side is higher]
I can adjust ride height using the left height sensor, but it equally adjusts height for both sides. The right height sensor does absolutely nothing, however, on the bench it tests perfectly to the Toyota specs. Other than this, the ride height works fine [lift and lower both sides].
I am starting to think that the solenoid valve or ECU could be defective but I wanted to hear any other ideas.
PS: I did think about KDSS lean, but it is leaning the other way.
'08 GX470 with KDSS
BILSTEIN B6 4600
