I've been planning on istalling some mechanical gauges onto the A pillar of my 60. Today I just happened to be driving by Pep Boys and figured I would stop in and check it out. They had some of the Auto Meter Pro Comps at a good price so I had the guy unlock the case they were in and check to see that they were illuminated. He opened the box for the oil pressure gauge to confirm they were and I also grabbed one for the water temp and Volts. When I get home I open up the oil pressure box and pull off the void tape to check it out. Then I open up the water temp and the void tape has been pulled off and stuck back on with another one over the top of it. WTF? Then I notice that there is no wiring/tubing inside. I open the Volt gauge box and the void tape is gone and again, nothing but the guage.
Yeah, I probably should have checked them before paying for them but we looked in the OP box and everything was cool. I figured if they were in a locked cabinet they should be intact. The only folks who could canabalize them would be the folks who work there...no? Anyway, a phone call and run around with no confirmed answer as to when they will have more in....frig it, I'll take my money back and go elsewhere.
So on a lighter note:
The OP gauge came with plastic tubing. Anyone ever use that? Or should I just go ahead and get copper tubing for setting it up (when I buy another set of gauges)?
Thanks,
William
Thanks,
William
