Nicksfj-40;
Keep in mind that an old (or new) FJ-40 will have a lot of RFI induced into a non-FM style radio system.
Inter-grounding of FJ panels, axles, fenders, fire-wall & Frame does help, but does not always help.
Filters, such as these:
http://www.powerwerx.com/search.asp?Action=search&Keywords=filter
will help; but, they help on the low voltage side, not the RFI side, spark plug side, which generates goobs of noise.
That does'nt help much does it?
I've been messing with this for years on my FJ-40 and have not solved much; except using FM on VHF/UHF systems.
As far as grounding ur CB goes, do this:
Use 1/2 inch tinned strap (not a piece of wire) from the Radio to the roll bar. Use 1/2 inch tinned strap from the roll bar to the FJ-40 body. Use 1/2 inch tinned strap from the body (fire-wall) to the engine block and then to the neg battery terminal or cruiser frame. Be sure grind off paint; metal-to-metal contact.
the reason for strap vs wire is that strap is a low impedance to RFI noise while wire (say, #10) is/will act like an antenna to noise and radiate same into ur radio. The 12v input should be thru a filter and as close to the radio as physically possible.
This subject can be very complicated and studying same will create mind problems - beware.
