I'm doing a cut & turn and using Dave's (4Plus) axle extender sleeves on both sides of housing.
On the short side especially, I had to grind most of the seam weld down smooth getting ready for the C&T, adding sleeves, Marlin knuckles gusset & Ruff Stuff perches.
So wanted to know if I can grind down the rest of the seam welds or if that will weaken the housing?
The rear SF axle housing is getting Dave's FF/Disc conversion bracket/set up also.
I'll take pics of the C&T, sleeves, knuckle gusset, perches and rear SF to FF & Disc conversion build and write it up with lots of pics.
I'll try to find some pics to post of the sleeves & SF to FF/Disc brackets. I haven't ordered them yet.
I want to get the new frame built first then get the housings finished.
Cheers, Allen
Cheers, Allen
