I recently noticed the glow plug light coming on after the motor had started. The time delay seems variable - about 50 secs when cold ( ambient here is around 15 deg C) and 8-10 when hot.
After a little investigation, what I have found so far is that from cold, with the ignition key in the 'glow' position, the glow indicator comes on for ~ 3 sec, power to the busbar comes on for 8 sec, off for 2, on for 3. If I start the truck when the dash light goes out, it starts just fine, and there is power to the busbar as soon as the engine fires, and as far as I can tell, stays on.
I'm thinking faulty timer, but despite taking most of the dash panels off, I've not been able to find it!
I have a copy of a FSM for the 1HZ, but it's dated Feb 1990, and lists HZJ70, 73, 75 and 80 series as applicable models, so I'm not confident the diagnostics ( even if I could find the bl***y timer!) are relevant.
Questions;
On a 2003 HZJ79R where is the glow timer located?
Any other thoughts what the problem might be?
Cheers for any help!
Questions;
