Generator Enclosure ideas
KLF
Frame waxer
Southern NH
I'm installing a backup generator system for my house, and I really don't want to deal with it in the way in the garage, and having to move it outside when I need it. I want it permanently mounted outside in an enclosure, hardwired to a transfer switch. My generator is a Generac GP5500, but at some point I want to upgrade to an electric start unit, running on propane.
Wondering what others have done for an enclosure. I have found these so far, not really impressed:
Gentran Corporation: Generator Transfer switches for home & business
PowerShelter Kit II
I'm concerned about a plastic enclosure taking the heat, and I can't figure out the best way to get the exhaust out safely enough that I'll feel comfortable having it running unattended. I also think those are overpriced, but I'm having trouble sourcing similar parts to make my own.
A place local to me sells this setup:
http://www.generatorconnection.com/PDF/The New Englander Edition Tri-Fuel Brochure 4-13-09.pdf
I can buy just the steel enclosure for $500 (including the concrete pad, but not the solar charger), which also seems steep, but I think it's the safest. I'm not sure what you do about maintaining the generator (changing the oil, etc), seems like a pain to have to take the front of the enclosure off just to do this.
I'm not concerned with noise, I live on 3.5 acres, my closest neighbor is several hundred feet of thick woods away, I'm mostly worried about safety, convenience, and durability.
Any other ideas?
Subscribed to this one.
I pre-wired my house for a generator when we built it, but never bucked up for a stand alone generator. Just using a 6000w gas unit when necessary. Luckily no need yet, but down the road I'll be in your shoes. Good luck.
We went 6 days back in December with no power, and have lost it a few times since then for a couple of hours. With no real backup heat source and no water, it gets old fast.
My business do that exactly, but for much larger units.
First post your generator model and data sheet if you have one.
Our enclosure are custom made, but we do have a design for small units.
Obviously you will probably not order a small enclosure from north of the border but i can probably help you in designing one, or deciding what you need.
Most important is cooling of the enclosure, does you generator have a radiator with fan? If not, then you need to find out the rejected BTU when the generator runs at full capacity, and from there i will tell you how many cfm are required to vent a enclosure.
EDIT: do you already own the generator?
Thanks.
My generator is a Generac GP5500, here is the spec sheet:
http://www.generac.com/SpecSheets/0180610SBY.pdf
Air cooled engine, but nothing mentioned about rejected heat. Honestly, I would probably leave the door open when it's running, just to be on the safe side. But I also feel it needs a ventilation fan. Yes, I already own it.
Built a ply wood enclosure, cover it with vinyl if you wish, then get a inlet louver for 750cfm @ 500pi/min not higher or you will suck up water (when raining), and find a 750cfm axial fan @ 1/2'' of water and a back draft damper for the air outlet. Based on 3500 watt heat rejection. Engine must be a G390 from honda 13 hp. Maybe heat rejection for such a engine is less or more.
EDIT: And a 10 deg F temp raise through the enclosure
I am not fond of keeping generators outside unless the enclosure is totally waterproof and insulated. Dampness is one enemy of the gen unit itself. I would just keep it in the garage and save the $$$.
I built a lean to shelter for mine. Works fine. When running, the generator produces enough heat to keep things dry... just my .02
Generally I agree with you, but I need this final setup to be easy to swap over to backup power, in case my wife needs to do it while I'm not home. There's no way I can expect her to muscle that thing outside and deal with the cord, especially if there's a foot of snow on the ground. Hell, even *I* don't wanna mess with that. She has a bad shoulder already, barely enough strength to pull the cord to start it (which is why I want to upgrade to e-start in the future).
Could probably just build a wood water tight box with a sloping roof. Hinge the front to drop down and yer done. Depends on where your exhaust/ muffler is pointed tho.
I would do a "dog house type enclosure"...pick a few details to match the existing house...than have one whole side or both for that mater, to run or do maint. KISS
