Ok Gang need to know what gears came stock in the 80's ? i think its 4:10's not sure and will the 80 series ring and pinion fit the 60 series set up ? any help would be Awsome
Dan
Dan
Yep, 4.10's on the 80's and yes the rear axle gears will fit in 60 series thirds. RustyDan did that swap, so he can better advise exactly what is needed.
I don't know if it is still there, but the Reno Pick-n-pull had (two weeks ago) a 1996 LX450 with 134k mileage that had the complete rear axle, so there is a complete third ready to go, not sure if that would work for you, but might be an option for one end of the truck.
Jack
That reminds me...I forgot to ask you...this one wasn't a good candidate for the sardine can experiment?
Actually, I have a better idea for the experimental vehicle, just have to find the right one. I found one in WA: '96, 350+k miles and right at $2k for purchase price. Timing just isn't right. After Alaska, I will be on the hunt. Then the games will begin.
Jack
What's this about!?
Well, my eventual plan is to cut out the roof of an 80, adapt a flippac type camper to the roof, and make the 80 into the ultimate backcountry camper. You know Volkswagen Westfalia style only better.
Dan is referring to my idea of finding a cheap 80 to "proof" my idea on. I don't want to cut mine up in case my idea doesn't work. Second, I have decided I need preferably a 96-97 because that gives me a ton of extra parts for mine. One being a motor that I can take me time refreshing and then swap into mine. Clear as mud?
Jack
