The gauge fuse blows on our 90 Cruiser after the engine heats up. As long as the engine is warm, it will continue to blow.
When I started trying to trouble shoot it last week, I found that none of the resistance readings on my gauges and the coolant temp sender matched those in the spec tables in the Mitchell Manual for 90 Toyotas.
I checked a new coolant temp sender and found the resistance on it to be close to, if not the same as mine. I had my meter checked and its accurate. Sooooo- I am inclined to think that the specs in the Mitchell tables may be off-- or ---that I'm screwing up somehow.
Before I pull anything else apart, I'm hoping that I can find someone with some ideas on what's going on here or where I might get some helpful info.
Mike in Bzeman
Mike in Bzeman
