Gap on passenger mirror
Rockville, MD
Hello all,
I am not sure if anyone has encountered this issue and found a solution. So, I have a gap on my passenger side mirror (2016 LC200). I can jam the gap together but am concerned it may break other parts, negating any possible and resulting in a full mirror replacement. I have already put a little pressure with bare hands on the gap, but without much success. Maybe using a flat head screw driver could work.
Anyone have suggestions from prior experiences?
Thanks!
I watched this video
Linked in this thread
Thread 'How to replace side mirror retract actuator (at least how I did it)'
How to replace side mirror retract actuator (at least how I did it) - https://forum.ih8mud.com/threads/how-to-replace-side-mirror-retract-actuator-at-least-how-i-did-it.1229467/
To learn about the side mirror. That cover is held in by some clips. The clips are around the outer-ish edge and in the middle of the mirror. It looked like you had to remove the reflector to access the inner clips.
Thanks for the share! It definitely looks to be quite an undertaking to take this apart without damaging the plastic parts.
