Fzj80 transfer case into uzj100
FOG TOWN->SF<-
I have noticed that my transfer case on my Uzj is weeping a little from the front seal and I know that Both the Uzj and the fzj both uses the same transmission.
My question is "are the transfer cases the also the same"? Only reason is that I have an fzj80 late model transfer case that is laying around the storage that I would like to swap if I could.
If they are not the same, I know that they must mate since they both run the same transmission....
Do you think I may have driveline issues and new drive lines may have to be made?
The 100 series does not use the viscous coupler. FWIW.
I have one installed with Marks gears and custom driveshafts. The drain port sits 1 " further forward and that the speed servo is the same. Can give measurements if you need them.
Edit: Re-read your question. You will definitely need custom driveshafts. Mine are OEM'ish.
