Green Lantern
Have Truck, Will Travel
I haven't wheeled with it, but here is the driving results for my VDO pyrometer installation. The thermocouple is installed on top of the exhaust manifold, in a flat spot between number three and number four exhaust ports (counting from front to back). The outlet pipe is attached to the manifold from below at the number four port.
1981 BJ42, stock with 3B motor, approximately 75,000 miles since receiving a 3B motor from a BJ60. Neither Rob nor I know the complete motor history. No turbo. 4.11 gears and 33x9.5 tires. The speedo is accurate. No tachometer though. I live in Texas. It's flat. We don't have mountains, only overpasses. Most grades are 3% or less and can last for miles.
Driving around the neighborhood, the pryo shows 350 to 450 degrees F. Driving 60 mph on the highway, the pyro sits at 650. Climbing a long grade it will go as high as 850. I got the pyro up to 950 passing someone around 70 mph. Under load the needle moves quickly. Thankfully, the needle drops quickly if I get off the accelerator.
This is old news to most of you. Hope it helps other noobs like me.
Happy Trails! N
Happy Trails! N
