I replaced the 30 amp fuse on the Camry's power window/door lock with a 40 amp fuse. When to get new 30 amp fuse and they also sell a 30 amp fusible link. Not knowing what I need I looked in the owners manual and it did not help.
This makes me wonder about the 80.
I bought a bunch of the larger fuses for the 80 years ago and took them out of the package and they are sitting in a ziplock bag in the glovebox. I know don't know what I have in the bag, they may be fuses or fusible links as they look about the same in the store.
What is the difference between the almost identical fuses and fusible links?
Does the 80 use fuses or fusible links or both? Can they be interchanged?
I know you should not go to a larger fuse but does going from a 30 amp to 40amp a big deal?
This is what the fuse looks like.
The fusible link. There is just a little difference between the two.
