Funny vibration in park
04' LX470 with OME suspension and Slee dif drops, all AHC removed.
When the car is in park it makes a funny vibration from the front motor area, if I put it in neutral it goes away, it also goes away the second I hit the pedal for an increase in RPM. I have confirmed that it is not a heat exchange issue on the exhaust. Thanks for the help.
I had this same problem with a previous vehicle and it turned out to be an engine mount.
Try pulling the E brake before you disengage regular brakes after coming to a stop, putting it in park, then letting off the brakes.
But yeah as Julian said, born to make all kinds of strange noises that don't actually matter.
I just did my timing belt & before I did it, it vibrated as hell. I think mines vibrated due to the skid plate under the truck. I haven't reinstall my plate yet & it haven't vibrated. I'm going to shoot a bead of silicone caulking around the edges of my skid plate and let it dry. Then reinstall so the caulking with absorb the vibration while driving
