I rebuilt my t/case on the weekend and once I started driving it, I noticed that its a bit noisier than before. It's not insanely loud, but definately more 'bus-like' than before. I took the PTO box off the side and noticed that my idler gear teeth have a ridge worn in them about 1/3 towards the front of the gear. I don't rememebr seeing this when I had the whole thing apart. I drained the gear oil at 1000k and found a bit of metal filings on the drain plug but no big chunks.
Has anyone seen wear like this before? I put a feeler gauge in behind the rear thrust washer and it seemed to be within specs (it was kind of hard to get the gauge in there).
I used the rebuild kit from 4 wheel auto and replaced all bearings, seals, etc.
The other thing is that the t/case seems to run a lot hotter than before.. After an hour or so I can only hold my hand on it for a few seconds. This seems too hot but I never checked before so I don't have anything to go from.
Does anyone have any ideas before I pull the back half of the case?
