fuel pressure regulator
hey guys i just put a 32/36 weber on my 74 f and it is getting too much fuel and flooding does any one know where to get a fuel pressure regulator nay help is appreciated
If you're still running the stock pump then fuel pressure is likely not what you wish to adjust. Weber carbs tend to be set up rich out of the box and (especially for an f engine) therefore may need a jet change. If your plugs are coming out wet I'd come down at least 2 jet sizes and more likely 3.
If it's used it may also need a needle and seat.
no it was a new one it seems that the bowl is overfilling and it is running out where the air horn sits on the body of the carb
Theo raises a good point. Be sure the float is not stuck or adjusted too high and pouring gas into the intake. I'm not sure how much gas you're talking about getting into the engine.
If it's not floats/needle valves then I'd go back to jetting. Create a vacuum leak (pull of the brake booster line) and feed it some extra air. Based on what the engine does you'll know how much extra fuel it's getting.
