- Joined
- Jan 7, 2013
- Threads
- 20
- Messages
- 289
What's the purpose of the small return line/hose that runs parallel to the fuel filler hose and connects right below the fuel cap?
I'm confused. Isn't the cap vented anyway? If not then its a sealed system. Wouldn't that create a vacuum in the tank?
no, the cap is not vented.
Haven't you seen the threads about pressurized tanks?
I had the "big whoosh of gasoline vapors when i remove the gas cap" issue, and cleared it up with that autozone vapor canister.
I'm probably wrong about the boiling point.
If your gas tank doesn't vent when you remove the cap, either your vapor canister is still good, or it's venting somewhere else.
