FSM maunal download problem
Lafayette, LA (Tha Bayou)
I have created an acount on http://techinfo.toyota.com, paid the $10 fee for 1 day, and I have located all of the files but I can not download the files for some reason? I followed the instrcutions and setup Internet Explorer to allow popups from: http://techinfo.toyota.com? One previous post said to uninstall Adobe so that the pdf file would not try to open once clicked on - and I have done that. As soon as I (left or right) click on the file to download - another window of Internet Explorer flashes and then goes away without givign me an option to view or download the file? I know ther is some setting I am overlooking... Any suggestions - I am on the clock!
Hmmmm I just looked at the site..ck'd out a sample wiring diagram and service manual clicked on the save ICON, sent both to my desktop and or doc. folder. :confused:
Read the process described by ComputerBookStore. https://forum.ih8mud.com/showthread.php?t=63217
Off-hand it isn't obvious what problem you are having. Many of us have successfully downloaded the manuals from TIS; both manually and automated.
BTW, you can get up to 48 hrs. Your "day" starts when you sign up and goes through midnight the following day. At least that is the way it was a year or two ago. You can also contact TIS and explain your problem and they will extend the subscription or give you another day after you get your problem worked out.
It's been a long time since I downloaded but I believe you need to have Active-X on or Java enabled or something like that.
-B-
BTW - It only took me like 2 hours to get everything in the FSM.... And I clicked each file and renamed using the zip file in a previous post that had the complete directory structure with filenames - A huge help...
